zluster
- Colorado Baby!
Working on a 01WJ replacing the front axle housing. Housing is bent and the passenger axle shaft is bound up and won't come out. Right now I'm thinking that if I can get the cross shaft out, and then the spider gears out that I will be able to put a rod through the drivers side tube and try tapping the axle shaft out.
BUT; There does not appear to be a bolt to remove to let the cross pin fall out, and I've tried giving it a few taps and nada.
So.....anyone know how to remove the cross pin from a D30?
any other thoughts for me?
