has anyone made some hinges to make xj doors easy to remove, 6 bolts a door is to many to take off and put back on. any ideals would make this summers wheeling alot more fun.:spin1:
cut the lower part of the hinges off so the doors can be easily removed and installed. youll have the drive the pin out and reinsert from the top on the passenger side. the wires can be unplugged. im sure there are many threads or write ups floating around here.
(2) The hood, hood latches, hood fastenings, doors, and door latches shall be maintained in a condition sufficient to ensure proper working equal to that at the time of original vehicle manufacture.
(1) Every motor vehicle shall be equipped with a mirror mounted on the left side of the vehicle and so located to reflect to the driver a view of the highway for a distance of at least two hundred feet to the rear of such vehicle.
Sounds like it's up to interpretation like every other vehicle law in this country. The question is whether or not being doorless constitutes a violation of the OEM's original intent i.e. wrangler doors are designed to be removable, but cherokee doors aren't.
