So both the doors on my XJ and ZJ are removable but the sagging is starting to drive me nuts... it takes two hands to close or open the doors, more so on my ZJ... so i got to thinking... what if i shimmed the hinges at an angle, like put washers on just the bottom bolts to angle the hinge upwards and theoretically compensate for the sag? would this work? has anyone tried this? The zj only has 2 bolts on each hinge, one upper and one lower, the XJ will probably require some shims in between the bracket and mount not through the bolt...:smoker:
