http://ststurbo.com/home
Check this out. Better yet, check out the latest 'turbo' magazine for more info.
This turbo system is basically a clever packaging solution. So clever, that it seems to overcome the obvious drawbacks to remote mounting.
Most of you will have a knee jerk reaction and blurt out something about turbo lag. Yes and no. Mostly no. This is a 'light pressure' turbo setup...like on SAABs. The stock compression ratio isn't changed. Boost is moderate. All eight cylinders on a V8 are spinning one larger turbo instead of two smaller turbos. Larger turbos are generally more efficient. Larger engines (V8 truck engines) are already tuned for low end torque and throttle response...so the turbo doesn't need to be. Why make more power at low RPM anyway? The tires just spin. In my opinion, a single, large light pressure turbo is a great match for a domestic V8. The only things left to cause turbo lag are the VOLUME of the exhaust and intake pipes. Since there is no intercooler VOLUME, then those pipes won't cause much lag. The exhaust piping to the turbo can be smaller and straighter than a normally aspirated performance exhaust. The pipe after the turbo can be huge and short...creating a better pressure ratio across the turbine. The compressor inlet tube can also be big, short and straight. All that is left is to minimize the bends of the pipework going to and from the engine.
I still worry about the cat and the stock O2 sensor. How will they survive the add-on turbo? They weren't designed to deal with the pressure.
If this technology were applied to an XJ, then you'd have to worry about keeping the turbo protected from rocks, water and dust. A skidplate and snorkel would do it. There are 4 locations the come to mind.
1. Turbo where muffler used to be. I'm luke warm.
2. Turbo where gas tank used to be. Use a fuel cell inside, like Jeepspeed.
3. Turbo in custom back bumper! For a few more feet, you get absolutely straight intake and tail pipes. Air goes in left side COLD---comes out right side HOT. :laugh:
4. ***hardest-core option*** Turbo in custom front bumper. NO exhaust under the Jeep.
Other little things make me like the remote mount turbo, like weight distribution and stealth. Weight is low and in the rear. No sign of turbo in the engine bay. I'd like to see something like this on the 6.1L Hemi Charger in a few years. :looney:
