I'm in the process of wiring my OBA and I am stuck. I'm not an electrical guy and don't know all the types of relays. Here are my parameters: Off at 125 psi (pressure switch), off in Drive or reverse, On in Neutral or Park, and On below 80 psi. I am planning on running my leads from the Neutral safety switch to a relay and then I imagine I'll need a relay coming from the pressure switch, but I'm lost as to how to combine the two relays. I thought that a latching relay might work for me, but I don't know and I'd like some advise. Maybe they have relays that will require two electrical imputs before switching over and will drop out if any of the two are lost? Thanks guys!
