Engine One Eight
- Tulsa
Went to Harmon's in Tulsa and found a salvage 2" Valley receiver hitch off an XJ. I need some tips on the installation process. It did not have the nut strips with it so I fabbed up some of my own, however, I will have to remove the rear bumper and bumper mounting bracket to slide my nut strips into the frame rail. Is this the same as with the factory strips or were they welded to thin enough metal that you could get it into the frame rail without removing the bumper?
When removing the bumper, there appears to be some rivit looking fasteners between the bumper and sheet metal. Obviously I have not started removing the bumper and was hoping for any tips or tricks I should know before starting.
Thanks
Engine One Eight
Thanks
Engine One Eight
