Like Tim said pretty much the only reason they talk about the rear axle is because there is such a wide array and options for rear axles, where as front axles is the 30, 44, 60, or rockwell for commonly found axles.
I would have to disagree here a little bit. There are a wide variety of different front axles as well but the ones listed above are the most common.
GM 8.5, D50, T8, Samurai, JK44, Ford 9" are a few others that are also common. Each has its place in the strength tree however parts can often be difficult to find.
