rear swaybar needed
Maximus
Bakersfield, CA
Anybody have a spare rear swaybar lying around that they just want to give away or sell very cheap? I may need one very soon.
Thanks!!
I am putting in a rear coil conversion and I think I will need it to keep the back under control.
How about a swap for some of that aluminum that I didnt bring to Matts place. I hav it here just waiting for you.
I will be there on Fri also. It should be about late mornign early afternoon, I will be in Shingle Springs and then Cirus Heights and who knows where else. Call me on my cell (209)815-4827.
Jes said:
Sorry I missed you.
I was at URF headquarters building junk all weekend.
Jes
So, how's the junk coming along? :)
Getting there.
The 8.8 gears are setup in a new housing and it's got doors, a hatch on it again, and a three link that's almost done. Fabbed and installed a set of my custom corners on it as well which took me a mind numbing amount of time.
Jes
whenever we can hook up that would be cool. I have been real busy lately so sometimes it makes it hard. I wont do the rear for a couple of weeks now so I have some time.
Mine kicked my butt also, I would of thought you would of had them down by now though :) I did mine the hard way, I am just a little retarded, :) I started with plate and strips of steel and cut and bent everything to fit. I really should of just had them bent.
Jes said:
Getting there.
Jes
You bet any time you are in the area, If you want you can drop off some of that AL also :) Let me know if you are around near lunch time, I'll treat you to In-n-Out :)
sounds good to me, I am trying to hook up with Sean P also if I can find his number again.
I have a lot of that AL so I will keep some for you.
