A picture is worth a thousand words. LOLlowrange2 said:Cut a piece of 1x1x.25 tube in half to make a U. Then drill a hole in the bottom center, stick the appropriate size bolt in and beld the head of the bolt to the inside of the tube. Then weld the tube to the axle. Now you have a nice box with a stud sticking out of it for your shock to mount on level with the axle tube.![]()
Why? You have to cut them off anyway, and then you already have a free shock mount. Why spend $30 more.jimbow912 said:I know about cuting the shock monts in half and bring it up but I dont like the feeling though I just want to know if there is a shock mount that is shorter that I can swap
That's an excellent idea :clap:bcmaxx said:I bought one weld on leaf spring perch ,cut it in half drilled two holes and mounted some shock studs to them. Its nice because you can bolt them up to the shock and move them side to side and up and down to mock them up before you weld them on
