Rear disc conv. cost?
XJHOX
Erie PA
What should I expect to pay to do a junkyard swap for rear disc brakes? I can probably get a ZJ disc D44 for next to nothing. I also see that you can buy the axle retainer plates from the dealer, any idea on the cost of those? Thanks Jason
My buddy has found a decent Jeep junkyard and has gotten me a set of backing plates and caliper mounts for $50. He got me a set of core calipers for $30.
ROB
Sorry for the bump, but does this retainer plate replace the need for a custom spacer like madxj used? Because I am in need of both retainer plates and a spacer....will this work correctly?
yes it replaces the custom made spacer... but XJ and ZJ axle flanges have a different bolt pattern, so you will either have to re-drill all the brake parts, or re-drill the axle flange.
