RWKHausSupply
- yorba linda, Cali
I have a left over D44 from a JK Wrangler (will not "bolt in" to a XJ without cutting brackets off and welding on purches)..
This D44 (and all JKs) has the larger tube (not like the TJ) and takes the larger D44 gear set with D60 sized pinion.
This is a complete, still with oil even. Has backing plates, rotors, calipers, caliper brackets, etc. is missing a few caliper bolts (about 20$ at dealer).
3.21 ratio now
takes a 5x5" wheel but wheel adapters are avail for either your 4.5 to 5" pattern and then same width F to R. Or 5" to 4.5, etc...
300$.
If you take it and strip it and bring it back without oil or shafts, I will regear it to 4.88, 5.13 or 5.38 for only 175 total more.
This housing has 0 off road miles. not one bracket is bent or folded etc.
located in Yorba Linda
3.21 ratio now
300$.
