rear axles
Really Twisted
St.Helens OR
:repair: I bought another xj last night for the motor/tranny. Its the magical 87 liited. I have found that it appears to have a 44 in the rear. Here's the #'s off the id tag 8953005003 46-13 3.54. I have not been able to crawl under and check the tube #'s yet. :confused1
the cover should look like a shield shape, rather than like an oval. all the XJ 44s that I've seen have had a fill plug that stuck out, and was square, as opposed to a fill plug that is an indent where you stick a 3/8" drive into.
hope it's a 44!
Mambeu said:
Too bad the attributes of some of those axles are exaggerated. Look at http://www.yuccaman.com/jeep/gear1.html for real live pics of the above axles. C8.25 won't be an option if it's an original '87 axle - you had either the rare D44 or the more common D35 that year.
