95XJ_Cbiscuit70
- South Jersey
Vent for axle appears to go into unibody frame at rear axle. I looked in the FSM and there is no mention of it in the rear suspension/axle section.
Where does the vent line go inside the unibody frame?
Has anyone come up with a better way to vent the axles by extending the breather up higher? Front seems easy enough as you can run up to underside of hood yet rear doesn't seem to provide any decent options.
Thanks
Thanks
