rooster
- Phoenix, AZ
RE Super-Flex 2 adjustable control arms.
Do they rotate at the adjustable length part in addition to the rotation of the spherical bearing assembly?
If the ansewer to the above is "no", then does the spherical bearing assembly have enough movement (degrees of rotation) as to not become a binding/sticking point during articulation with RE 4.5 lift?
Adjustable preload of the sperical bearing assembly. How much? Is there a torque # or is it by feel?
TIA
TIA
