RC 4.5" front coil 6 months old $90.00
01erionracing
As the title said I have the RC 4.5" RC coil for $90. I bought from RC and installed in my XJ since last Dec. Upgrade to 5.5" Deaver.
Contact voice or txt Jimmy 951-219-6631
Did some searching and found out XJ coils will fit on ZJ but will net up less 1.5-2". Let say this is 4.5" from XJ may lift about 2.5"-3" on your ZJ. Hope this help.
You know the spring rate on these? I'm looking for 4-4.5" and these could be useful...I run without sway's so I need something fairly stiff.
hmmm, if i bought these, i would get around 2-3 inch lift in front then switch my front springs to my rear will be around 3-3.5
you think the ride quality would be either the same or better?? for on road use?
I'm mostly driving on streets and looking for something stiff as in bumps would be nothing, rides smooth without wobbling etc.
Plus without adding anything just new springs atm.
