Radio Compatibility
skywalkr
Jacksonville
I am looking to move into the 21st century by upgrading my cassette radio...
I have found numerous OEM radios on Ebay such as the RES and REF out of Chrysler vehicles but am wondering if they will fit in a 97 XJ...I am not opposed to making a custom mounting bracket if the dimensions allow it...
I just like the newer OEM radios as opposed to an aftermarket pioneer or the like...and it will allow me to use the UConnect system...
As long as it's a standard DIN or 1/2 DIN (forget which) it should be adaptable, you may need a bracket or something. To get a new radio into my friend's 91 MJ I ended up tack welding the bracket from his old Honda into the bracket from the MJ, worked great... first time I've ever used an arc welder to install a radio though.
Electronics are pretty easy to set up, the connector in the XJ has 8 wires for the 4 speakers, constant power, accessory power, a display dim signal, and one or two others I forget, maybe options for a powered antenna.
These all fit an 00 XJ and should fit any 97-01 XJ. Any simliar 3 letter code radio from the donor list should fit also.
- 4704 383AH 1 RADIO, AM/FM with CD and Cassette, (RAZ)
- 56038 933AB 1 RADIO, AM/FM Cassette, (RAS)
- 4704 393AD 1 RADIO, AM/FM with CD, (RBJ)
- 4704 392AD 1 RADIO, AM/FM with CD, (RBA)
Jeep
1996-1998 Jeep Grand Cherokee ZJ
1997-2002 Jeep Wrangler TJ
1997-2001 Jeep Cherokee XJ
Chrysler:
1989-1991 Chrysler Maserati TC
1993-1997 Chrysler Concorde
1987-1993 Chrysler 5th Avenue
1990-1993 Chrysler Imperial
1993-1997 Chrysler LHS
1984-1986 Chrysler Laser
1984-1995 Chrysler LeBaron
1984-1997 Chrysler New Yorker
1990-2000 Chrysler Town and Country
Dodge:
1987-2000 Dodge Dakota
1984-1993 Dodge Daytona
1987-1989 Dodge Diplomat
1998-2000 Dodge Durango
1988-1993 Dodge Dynasty
1993-1997 Dodge Intrepid
1985-1989 Dodge Lancer
1995-1999 Dodge Neon
1987-1993 Dodge Ramcharger
1987-2003 Dodge Ram fullsize B-van
1987-2001 Dodge Ram fullsize trucks
2002 Dodge Ram 2500 and 3500 trucks
1987-1994 Dodge Shadow
1989-1995 Dodge Spirit
1984-2000 Dodge Caravan and Grand Caravan
Plymouth:
1989-1995 Plymouth Acclaim
1987-1989 Plymouth Grand Fury
1992-1994 Plymouth Duster
1987-1994 Plymouth Sundance
1984-2000 Plymouth Voyager and Grand Voyager
:doh: I somehow completely missed the part where you wanted an OEM radio. Sorry about that!
ok, so thats a no on any 2002 and newer OEM radios?
This is where buying online fails...would be a lot easier if I could buy one at walmart, see if it fits, then return it if it didn't...
