xSirCyberx
- Western Washington
I finally pulled the plug a couple months ago and upgraded to a Cold Case radiator and went from a closed loop to open loop. I also got a high flow water pump and a triple e-fan setup on a smart switch and cabin mounted monitoring and control (this would be NickInTime's Trinity Fan Controller). When the radiator is full, I never, ever see overheating. However, I have leaks and this is where my question is.
I performed a full flush, but it took 3 months for the obvious leak to develope: freeze plug. Well before this, after 1 month, the radiator had some mystery leaks. It would leak and then not leak. The drivers side radiator hose would sometimes leak from the engine side fitting. It's been tightened and loosened trying to find a spot where it wasn't too tight but tight enough, and can't find it.
Observations: radiator cap has never released built up pressure. I am positive I don't have the overflow tank hooked up, but it's atmosphere pressure, it's not stopping the radiator from venting. The lower radiator hose and upper radiator hose build up a ton of pressure, I don't have a gauge to say how much, but a 15 minute ride gets both hoses very hard. They are flexible when cool.
Is it possible that the radiator cap from Cold Case is functioning incorrectly or malfunctioning? Shouldn't the cap release pressure? Could this be causing at least some of my issues and also creating new ones (such as the freeze plugs)?
Thanks everyone, I will post pictures and get advice for the overflow bottle later
