You'll need/want to find a way to reattach the fender liner to the fender probably (if you're keeping it.) You'll have to remove one or two plastic push pins to disconnect it from the air dam at the front, one self tapping screw under the front/back ends of the flare, and the 9 nuts on the boltstrips along the main portion of the fender. At least, on a 96... I think this is valid on 84 as well but I'm not sure.
