questions on vacumn lines
heshhash
Proctor, MN
im gonna be replacing the lines this weekend and i am wondering if i can remove all those plastic lines and connectors? would this be good, bad, or what...
/discuss on
Don't do it. Replace them.
Renix Vacuum Harnesses
The vacuum harness that attaches to the front of the valve cover and includes the grommet/fitting, and is called the front harness, is Napa part number BK 715-1367
http://www.napaonline.com/Catalog/Result.aspx?Ntt%3d715-1367%26Ntk%3dKeyword%26Nty%3d1%26Dn%3d0%26D%3d715-1367%26Dk%3d1%26Dp%3d3%26N%3d0
The vacuum harness that is closest to the air cleaner, EGR etc, and is called the rear harness, is Napa part number BK-715-1366.
http://www.napaonline.com/Catalog/Result.aspx?Ntt%3d715-1366%26Ntk%3dKeyword%26Nty%3d1%26Dn%3d0%26D%3d715-1366%26Dk%3d1%26Dp%3d3%26N%3d0
The tube from the rear of the valve cover to the intake manifold is part number 715-1365.
http://www.napaonline.com/Catalog/Result.aspx?Ntt%3d715-1365%26Ntk%3dKeyword%26Nty%3d1%26Dn%3d0%26D%3d715-1365%26Dk%3d1%26Dp%3d3%26N%3d0
Revised 09-11-2012
They are very important for many reasons. Removing them would cause many operating problems. Replace them.
