I just did a PORC SYE and put an XJ front DS in the rear.... What is the distance that the DS should be extended? The length of the exposed inner part of the DS is about 2.5". On the front it's only 1.5" ish.
i have the 8.25... I'll take some pictures when i get back. I also have a ZJ shaft just in case, but I don't think that I will have much compression on that one.
TY....Thats about what mine is...I seem to remember a smart comment from you when I asked a similar question a couple of weeks ago? about how much should be showing and how much travel there should be in the shaft.
anyways I have auto and 8.25 rear axle. Mine is extended about the same as you state, near 2.5" of the slip section showing. So far no problems, once I shimmed it correctly it seems perfectly fine the way it is. But like said above the GC ones are a little longer if you have the d35 rear axle.
well, i might experiment with throwing in the GC shaft, but saying as you have no problems i wont worry about it... besides, w/ typical geometry, the amount of downtravel i have shouldn't be enough to pull the shaft's apart.
