ian.jones5557
- washington
I have a 88xj that is strictly for wheeling. One of the reasons for push button is because I have been known to forget the key from time to time so that will help with that. Also I want the ability to quickly shut the rig down.
The panel replaces the compartment in front of the gear selector.
Each rocker is rated to 30 amps. It has its own fuse block with 6 fuses. Each circuit is rated to 20 amps, so I will be using a relay for the electric fan.
The second block is for all of the grounds on the rocker switches. Wired that way I can keep it organized and only have to run one wire to the chassis.
Tomorrow I will be wiring up the toggle and push button. Here's hoping I can locate the wires in the factory wiring harness without too much hassle.
