Samson04
- Taylorsville, KY
I have a 98xj 4.0 with 183K miles and a Skyjacker 3.5" lift and front disconnects. I run 31x10.5 mud tires. The ole' jeep has recently developed a pretty strong pull to the right while driving. It doesn't "Dive" but it will pull you off the road if you let go of the wheel. I jacked up the front end last night and there is no movement up and down in either of the wheels. I did however find a lot of grease "caked" on the lower ball joint area of the right front wheel. Is this my issue? Ball joints? I have had the jeep for the last 70K miles and have never replaced anything on the front end because it has all been tight and worked great. I do keep everything lubricated at oil change intervals and I check for movement then also. Any idea's on where to start my search? Thanks in advance for the help!
