gabe4
- upstate NY
Does anyone pull a popup camper with thier rig?
MA?mdl said:I run a 16" lift with 52s and I have no problems with mine. I have stock gears as well.
thanks for the helpmdl said:I run a 16" lift with 52s and I have no problems with mine. I have stock gears as well.
gabe4 said:How much lift do you have and what gears are you running?
This is the same set up as mine. When you did the SOA on the camper were you able to put a larger tire on, and how ruff a road do you think you can make is it just dirt roads or old logging trailsRKBA said:I tow a pop-up with my XJ. Jeep has 4.5" lift/32s/4.56s and the camper tips in at about 1500lbs when loaded for the weekend. I did a spring-over on the camper so that it can handle rough logging roads a little better.
:looser:mdl said:I run a 16" lift with 52s and I have no problems with mine. I have stock gears as well.
JnJ said::looser:
mdl said:I was obviously being sarcastic just to be an asshole... duhhh![]()
Okie Terry said:I'll say it for you John, "Post reported!".
What, I didn't report it!mdl said:lame
That's why I bought it, well for trips to PAP. This way I can just hook up and go and still have room for spares and other wheeling stuff.mdl said:I want to borrow one or NACfest
