Hiya,
I have a couple of noob questions for a problem that’s new to me. I’ve done a search, but not found much info.
I guess my power steering pump is going out. It’s begun making some ugly sounds: A growling rattle, and a bit of a squeek, too. I assume that these are coming from a failing bearing?
My Question: What’s the best (cheapest) way to fix this? Is this repairable, or do I need to just go buy a new pump? Is this a problem that can be fixed with a rebuild kit like this: Here. Will this failure contaminate the rest of the PS system, or is the bearing seperate?
If I go pull a pump from the junkyard, what years can I pick from?
Got any other advice for this project that might not be mentioned in the Haynes?
Thanks.
[FONT="]1994 Sport, all stock DD 4.0 AW4 100Kmi.[/FONT]
Thanks.
