kenny schmitt
- US
SO on my way to a mtn biking trip i notticed my 96 4.0 shut off at a light. I got it to the side of the road but not in a good area. So i smell gas and got some out of the fuel rail when i pushed that button. When i checked for a spark i had nothing. i held a key and screwdriver to the wires and the wire from the coil and the coil itself but ne spark. I even puller the cap and rotor it was pretty corroded but i cleaned it. i changed the coil but still nothing. Both the wires + and - have been spliced to hook up my tak and the negative has a wire running for the tak. by the way when i try start it the tak goes crazy up and down from 0 to redline. i dont know much about this but i put a volt meter to the wires going to the coil and could only get a reading when i put it on 200k OHM dont know if thats right and it went to like 4 What should i do. i thought it could be the wire going from coil to cap b/c i always pull it off of the cap when i leave the car sumplace, that and pull the fuel pump fuse (my theft protection) i thought it may have gotten a short but when i disconect it but i have no spark off of the coil. Im stumped guys what should i do thanks alot:repair:
