ktm racer 419
- ROW DIALIN
This is what you need if you want to get back your turning radius after swapping in a larger axle with longer knuckles.
Its just a fullsize jeep drop pitman arm, but its about the same drop as an xj arm, but an inch or so longer. You need it to match the throw of the longer knuckles.
Its the arm bjs offroad sells, used, but nothing wrong with it, paint is still in nice shape on it.
It accepts jeep half ton tie rod ends and chevy one ton tie rod ends, probably many others, can be drilled out for heims.
$50
$50
