I am in the middle of changing my pinion bearing. Just had a couple questions. and wanted to make sure i was right. Pinion nut torque is 200-220 ft/lbs correct? and the pinion preload is... not sure want to say around 20 in/lbs? anyways thanks for any help. i have been searching for hours with no for sure answer. Its a Dana 30 rev with the shims not the crush sleeve.
Thanks
Thanks
