parts need gone
mcguyver_xj
Grandby, MA
everything located in holyoke, ma
97-01 header panel bright red with all lights and trim pieces and harness $80
97-01 taillights $25 (one pair)
98 xj gauge cluster with 133k make offer
98 xj ecm automatic with cruise control $30
full set of tj flares missing one lens make offer
97-01 front wiper motor make offer
97-01 rear wiper motor make offer
97-01 center console latches $15 ea (have 4)
c8.25 Ruffstuff diff cover with hardware needs paint...$70
d30 Ruffstuff diff cover no hardware and needs some of the countersunk holes touched up...$50
set of d30 axle shafts need ujoints $40
got a 2wd aw4 that worked and had clean fluid if it doesnt sell ill just scrap it make offer
-also any interest in the exhaust manifolds and converters off a 2000 xj with split manifolds?
Also got a rear disc conversion backing plates made to fit an 8.25 with no working ebrake, brand new rotors and pads and one new hose, calipers may need replacement as bleeders look like they won't come out I didn't try $175 obo
Disc brake stuff
97-01 header panel bright red with all lights and trim pieces and harness $70
-also any interest in the exhaust manifolds and converters off a 2000 xj with split manifolds make an offer
-97+ 5speed swap everything you need $500
-ax15 out of a 98 Xj $300 and I'll just keep the swap parts
-Disc brake swap for an 8.25 new pads and rotors $150 came off my 8.25 bolts right on
