Uglygreenxj
- Circle City, AZ
I was trying to sell it, but I'm just not getting anywhere and there are alot of parts I can use on my new build so I think I'm going to part it out. I will include a link to my webshots album so you can see alot of the stuff there. Everything is still on the Jeep but once I find buyers for the big stuff, I'll start stripping it down. Here's the stuff I'm selling:
1) XJ Dana 44 rear axle with 4.56 gears, spool, disk brakes, truss that ties into poison spider rock ring, anti-wrap bar mount, teflon hydrobump pads - $900
2) High pinion Dana 30 front axle with 4.56 gears, poison spider rock ring, truss under axle (jeepspeed style) - $350
3) JAZ 22 gallon fuel cell w/foam, 45 deg filler, remote mount filler, fuel sending unit, E2000 fuel pump, will remove and include sump to recess in floor for a fee - $500
4) Steel tail light housings for pre-97 - $50
5) Engine & trans - $800
6) NP231 w/Advance Adapters SYE - $250
7) Hanneman fiberglass front fenders unpainted - $250
8) Currie Currectlink steering - $250
9) Currie Antirock (the arms have a 45 degree bend to clear limit strap mounts on frame) - $250
10) Modine two row radiator - $80
11) Wheels & tires, American racing aluminum 15x8 w/BFG muds 33x12.50r15 (very low miles, still nipples on the sidewalls) there are five and the spare hasn't touched the ground at all. I've got the hazard warranty on'em from Big O - $1000
12) Two each Lightforce Striker 170 lights (I'm keeping four of them) - $240
13) Custom crossmember with RE longarms shortened about 3". They mount up high and inboard. Arms are parallel w/ front driveshaft. - $500
14) Deaver sportsman leaf springs 3.5" lift - $300
15) JKS boomerang shackles - $60
16) Custom lightbar that holds and protects 5 lights - $250
17) Front and rear new custom driveshafts for 6" of lift from Precision Driveline - $100 each
18) RE 5.5" lift coil springs - $100
19) Banks stainless steel header - $200
That's all I can think of at the moment, and obviously any of the other stock stuff. I still have the stock gauge cluster too.
Please PM me if you are interested in anything. I'm not interested in shipping anything yet at this stage of the game.
Thanks for looking!
Thanks for looking!
