The name of the part that the oil filter connects too. I had a leak which I thought was coming from the filter and pan gasket but turned out to be the part that I'm not sure what the name is.
You probably already know this, but if you have a '93, AFAIK your adapter will require a hex bit instead of a torx. I got one sometime ago but haven't gotten around to doing the job yet so can't swear I have the correct shape but do know what I have is just a touch too large. Don't recall the size offhand but someone will confirm or you can search.
