Moo Moo Jeep
- Colonia, NJ
OK it's official I'm parting my XJ out. Whatever is left I'm taking to junk yard by the end of next week. It's 1993 Cherokee with 4.0L motor, AX-15 manula trany i NP-242 t-case (Full-time). It has 209,352 miles on the title and 174,068 miles on the cluster. I guess PO changed gauge cluster which would explane mileage difference and gauges not working. Jeep is located in Linden, NJ 07036.
Motor used to run good but since this week I can't start it anymore. I think fuel pump quit working b/c I can't hear it buzzing anymore after I turn ignition key. Last week I could hear it working and motor was running well. Brakes are not operational (power booster is not installed, some of the hard lines are missing). Last week I put front of the Jeep on jackstands (only front driveshaft is connected), started the engine and shifted through all gears several times to check if trans works ok. It does, no grinding or any other funny noises. Some pictures are on RC board but I can take more: http://www.rc4x4.org/rcforum/index.php?topic=18075.0
I can ship smaller parts on buyer’s dime but big ones need to be picked up or I can deliver them for gas money. Most likely I will be in RC at the end of October so I can take almost anything with me. I can take more pictures just ask what you need. All prices OBO.
I will take trades for 35”-37” Pitbull Rocker or Nitto Mud Grappler tires and for XJ parts like rock sliders, HD front and rear bumpers, aftermarket or stock front or gas tank skid plate, aftermarket motor/trany skid plate, light bar, rear quarter armor, tube doors, interior storage drawers interior storage basket or some other aftermarket XJ parts.
Motor, drivetrain & miscellaneous
Complete motor 4.0L w/harness, computer and all accessories (intake, exhaust manifold, starter, alternator, power steering pump etc.) $250
Radiator $25
Trany AX-15 $175 Sale pending
T-case NP-242 $75
Motor, trany & t-case $450
Motor & trany $400
Exhaust w/cat and cherry bomb muffler (nice low exhaust sound) $40
Metal gas tank (looks pretty new) $30
Front CV driveshaft $20
Rear driveshaft with slip yoke $10
Front axle HP Dana 30 complete w/steering, track bar and brakes rotors and calipers (might need to be replaced) w/4.88 gears, welded u-joints, LP diff cover, passenger side bumpstop pad is rusted away (metal bump inside coil spring). $250
I can sell 4.88 gears with carrier and bearings $150 but then I’m keeping axle shafts.
Rear axle Chrysler 8.25 rusted, 3.07 gears, no brakes (no drums, no shoes, no harware) $30
Suspension, Steering, Wheels and Tires
3" coil springs $50 Sale pending
Front nitro shocks good for about 5", made in Germany, were blue before I painted them black so they might be Bilstein, new black boots. I’m not sure but I think I removed them from lifted Wrangler YJ long time ago. $30 for both. Sale pending
2 stock upper arms $10
2 stock lower arms $10
All 4 arms $15
Leaf springs (rusted) and stock shackles free if buyer removes them. Pending
Rear ProComp shocks painted black, new black boots, good for 5" of lift, 1 has ding but works ok $15 Sale pending
Power steering box $25
Steering wheel $10
Steering column with key $15
Stock steel wheels 15x8 painted black. 4 stock Goodyear Wrangler 235/75R15 tires but 3 different models of them. 2 have about 50% and 2 almost brand new. $40 each new one (I paid $45 for 1 of them), $20 each used. Spare doughnut $15. $100 for all 5.
Body and interior
The whole body with whatever left
and clear title (209352 miles) $100
Hood $25
Header panel $20
Front fenders $30 for both or $20 for each
4 Wrangler stock cut flares $20
Front and rear doors have been modified to be easily removed. Front doors have small rotten holes in lower part (see pics) but I sanded and painted black lower part of all doors to stop rust. Manual windows, door locks and mirrors.
Rear hatch. If closed can be opened only from inside that’s why inside plastic panel is cut next to the lock.
2 front doors $50
2 rear doors $50
All 4 doors $80
Beige front seats with brackets and sliders $20 each or $30 for both
Beige center console $15
Beige dash $20
Free stuff if you pick it up. Sorry no shipping on these.
Dual-diaphrame brake booster
Gauge cluster
Gas pedal
Radiator overflow bottle
Washer fluid bottle
Head lamps
Tail lamps (right one cracked and have hole)
Turn signal lenses (might have some cracks)
Radiator $25
T-case NP-242 $75
Motor & trany $400
All 4 arms $15
Steering wheel $10
Body and interior
Hood $25
Header panel $20
2 front doors $50
2 rear doors $50
All 4 doors $80
Beige dash $20
Gauge cluster
Gas pedal
Washer fluid bottle
Head lamps
