Part mixing 231
M. Lake
Tucson AZ
I have a '91 NP 231 that has the back cover (one with tag) broken. It came out of a 5 speed. I have gotten rid of the input gear, and used chain on wife's '95 NP231, but it still has issues. I have a '96 NP231 complete. The '91 outputshaft housing is toasted.
Don't want the '96 case in my project jeep, would rather have older one in until I can get a D300. Was thinking of putting the '91 output shaft on the '96, so I can still lift the misses jeep around 3-4" without getting into a serious driveline mod. Then take the 231 that is in her jeep now and fix it to put in my jeep. Lifted already, and going higher. Would like to avoid buying 5-6 drive shafts just to have a temp (year or two) case in my jeep.
As stands, I have the abs system on my '93 rig, which gives me the 297X axle joints. I also have the D35C with stock LSD. I am going to put better axles on (found D60 rear with LSD, would like HPRCD60 front from ford) so I will not need the ABS crap on my rig. Want to put my D30 and 35 in place of her 30 and 8.25 (becouse the 35 has LSD, and the 8.25 is rock hugger) giving her the ABS system, axles with wheel speed sencors and stronger axle joints. Gives me the '95 break booster upgrade with new axles. The wife's jeep was pulled behind an RV before we got it, and I found some damage to the sub frame in front when I tried to put my stock skid on. I guess it had a good tug, or the RV hit something. But both sides of the subframe (6" or so back from bumper) is bent in on both sides, so this will not be a compatition rig, just about 4-6" of lift (depends on wife) and she does not plan on being the last owner (use for trade later). I myself, will continue to hack off what ever is damaged off mine until there is nothing left, then get an other one.
I will do it and find out what happens.
