Painting/powdercoating near SD
n1ywb
Hi All,
Can anybody recommend a shop that does powder coating or maybe painting? I'd like to have my rooftop basket stripped and acid dipped to remove rust and old paint and then preferrably powder coated. That's assuming they can do whatever prep work is necessary to keep the powdercoat from peeling off in big sheets like it usually does.
I go to San Diego Powder Coating in El Cajon, off Magnolia near the airport, they always did a good job for me. You will need to make sure any sections that bolt together get welded, in other words, don't leave any areas where moisture can work it's way into that is not protected by the powder coat.
