(1998 xj 4.0L Aw4)
Hi guys,
A while back i had my rear driveshaft rip my downstream Oxygen sensor wiring harness apart. I purchased a new O2 sensor and now im having some trouble splicing the harnesss to the new Oxygen sensor back together. The new sensor has two white wires, a grey wire and a black wire.
Does anyone know the function of each wire and its correspondence to my Xj's wiring harness?
I took a look at the front O2 sensor and spliced them the same but im still getting a pending P0138 code on my handheld code scanner.
Would splicing the two white wires on the O2 sensor wrong cause it to throw a check engine light.
The harness wire colors:
Brown with yellow stripe
Green with white stripe
Solid black
Light brown with white stripe
Any help is greatly appreciated! Thanks.
Hi guys,
Solid black
