jeeptec
- atascadero california
is there anyway to lessen or elimate tie rod roll with a otk steering. i dont want to go to a heim joint system.
yeah. keep the inverted Y and use an insert in the drivers side knuckle to run it OTK. no tie rod roll
i just checked out jcr. what a simple idea. very in expensive too. worth a try. thanks
bump steer yes, death wobble no.. But anyways the only way is the spacer things that JCR sells or make your own.
