My computer and dial-up connection are too slow for me to deal with Adobe pages. Also, I really can't give you specific advice for liability reasons.
All I can tell you is what I already wrote. To be legal in a house in just about any jurisdiction in the USA or Canada, a stove has to be tested and listed by U.L., U.L.-Canada, CSA, or some other recognized, accredited testing agency. The listing from U.L. tells how it was tested, and that's how it is must be installed to be legal (and safe).
Just saying a stove is U.L. listed doesn't say anything. If it is listed for 12" clearance, it isn't safe (or listed) if installed with less than 12" of clearance. The manufacturer's literature should coincide with the clearances for the U.L. listing, and for major manufacturers like Lopi I think you can rely on them. Off-brands, I would be less likely to trust their literature and I would also read the actual U.L. listing. If it isn't included with the stove literature, call the manufacturer and ask them to send it to you. If that doesn't work, call U.L.
There will be a separate listing for the flue pipe. That will also have a minimum clearance to combustible framing (for a double wall it will probably be 2", for a triple wall maybe 1" or maybe zero). Be sure you follow those requirements, also.
BTW -- In every square inch of Connecticut you need a building permit to install a wood-burning stove. That's also true for most municipalities in most states. Unless you live in an unincorporated area, most likely you need a building permit -- and even many counties have building inspectors and a permit process. You should find out if your area requires a permit, and who issues it. If you have a building inspector, he should be able to help you sort through the requirements for the installation. You should get it right, because it would be a PITA to finish everything and then have the inspector make you rip it out and start over.
