PMGaming101
- Sherbrooke Quebec Canada
I Need help !!!!!!
ok here we go my jeep will not start no more
this is what i did so far ( all new parts ) gas pump , fuel filter ,crankshaft position sensor,idle air sensor,oxygen sensor,new bosch injectors out of a Ford Mustang 5.0 ,new distributor,cap, plugs ,ignition coil , rotor wires, Fuel Injection Pressure Regulator, Manifold Pressure (MAP) Sensor,Throttle Position Sensor (TPS),Temperature Sender / Sensor not in yet !
its was running bad before i did all this . but now no start at all it wants too but will not .
anything would help
and for the distributor timing is right !
anything would help
