I installed the OME 3.5" leafs on my 99 XJ. IIRC, I could use the same OEM pins. However, I needed a longer pins because I was using degree shims to line up my pinion and SYE driveshaft. Hope that helps.
That is what I am doing. I'm installing a set of 6 degree shims and need new center pins. I can't take the current pin out to check the size because I need the Jeep to drive and get the pins from a local shop.
Mine required a 6 degree shim, too. I just installed some boomerang shackles and I wonder if they changed the diff angle. No vibes yet. I guess we'll see.
Specifically the 10th picture and related paragraph. Socket cap bolts work too. No need to round the heads, and they're comparable to grade 8, strength-wise (maybe stronger?). But they will corrode quickly.
^^^ This. I just used some 3/8 -16s. Whatever length you need. Pretty easy to find at the hardware store. You'll have to grind the diameter of the socket head of the bolt in order to fit the hole in the leaf perch but they worked perfect for me.
