HenryKrinkle
- WI
Hey guys, I just picked up a set of AJ's square super rails in really good shape for pretty cheap. Only catch is they are the older style. Each rail has: 2 L-plates with 4 holes per plate. Looks like the L will go under and then up the outside of the frame rail. There are no pinch-seam mounting points.
I don't know how old they are, but the seller is sure his friend had them on at least 2 earlier XJ's.
Anybody seen rails mount like this? Will the horizontal bolts go all the way through the framerail or just the outside? What kind of bolts (if any) only go into the framerail and don't use a nut on the other side?
This setup doesn't seem as nice as his current design, but does anything think jacking from them would be a bad idea? I know people use his pinch-seam-mounted rails to jack from...
THanks for any advice....
Oh yeah, I contacted the man himself (AJ), but he's likely busy and am wondering if any of you can help.
