Okay doing some perfomance mods Help...
Bville99gt
texas
Well I have a 2001 XJ lifted 6.5" with RC Suspension on 16" rubicon with 33x11.50" tires...Well starting to mod the engine but I have some questions, here is what its going on the xj (all parts that I have listed is because i've had spare from other builds)...If you have any suggestion i'm all ears...:D
4.10 Gears
Jet Chip for timing
Split Second PSC1
Crane Cam 753905 (Do I need the 97 Camgear and Timing Chain Kit?)
Nx Wet Nitrous Kit 75-100 shot (I've used 150 shot on my last Xj's)
Dual Electric Fan Conversion
Walbro 255lph fuel pump
63mm Throttle Body or mustang 65mm throttle body (need to buy either)
Header
Here is a pix of the XJ
you will need the earlier cam gear, cam bolt, spring and dowel. You will probably also need valve springs too. With 33" tires 4.11 gears aren't optimum. Search for that in mod tech. http://www.strokedjeep.com/ does a good job on the throttle bodies. Is that cam used?
4.10 Gears
Jet Chip for timing
Split Second PSC1
Header
Since your running nitrous and probably want to keep this fairly streetable?...call Lunatti....$200 gets you a custom ground voodoo cam, and their reps will work with ya on the phone so you get a cam that is EXACTLY what you want, and their one of the best camshaft companies out there.
Thanks man...:thumbup: I'll give them a call and see what they have to say
about the walbro255 fuel pump u got. is it a inline r drop in pump? is it for returnless fuel systems?where can i get 1? how much? i want 2 up my shot on my 96 4.7 from 100 to 150 but not till i replace the pump. nice xj by the way ,thanks. 96 xj 4.7 ross forged pistons,comp 206/214 dur cam,ported head, ported 99+ int,62 mmtb,30#inj,map adj,venom400 module,msd 6a ign +coil,borla header , 2.5 exaust,no cat,borla muffler,nx wet sys 100 shot,2985# 2wd xj
