Truckedup
- Western NY state
There's a large Torx head bolt securing the oil filter bracket to the block. It's bigger than a T-50. Anyone know the size so I can buy the right one the first time?
Once again, great time for the original poster to share with everyone what year, engine, etc.
Produced from 1984 through 2001, and there were a few different options and manufacturing changes along the way.
Hex, Allen, and Torx bolts were all used on the 4.0 oil filter adapter at different times.
1999 4.0. :shhh: I said it was a Torx head in the first post,used a mirror to see it. Oil has been seeping from the bracket to block joint for a few years.
I just finished changing the clutch laying on a creeper,dealing with this oil leak must be easier![]()
Thanks,I saw the link with the tool bit and long bar.I can make something similar....I don't care for big sized Torx bolts.The design seems to let the bit slip out when you crank on the torque.A hex head bolt would work better,no wrench slip and probably be less expensive.
My 95 required a two foot cheater bar on the wrench shown, and even then, I had to put a good bit of weight behind it before it snapped loose. Perhaps it depends on who was on the assembly line when your engine came through. I think someone was doing Ninja training the day they made mine.I have a 96 and a 99 right now and I was able to do this on the 96 no sweat. I had a 12mm on the bit that was in the socket and double wrenched it out.
The 99 on the other hand won't budge. My next shot will be when the engine is at operating temperature to help with removal. Poor mans heat wrench is what I will call it if it works.
My 95 required a two foot cheater bar on the wrench shown...
Which wrench? My wrench?
I have heard some people say that the bolt is torqued to somewhere north of 180 ft/lbs.
But so far no one who has used my wrench has relayed any problem.
That's very similar to what I came up with.Ok,I bought a 5 buck T60 bit. I punched the bit from the 3/8 chrome "socket', then cut the end from an unknown typical L shaped lug wrench and welded the bit to the end. Had to heat this hillbilly wrench to put a bend in it for best clearance to miss AC hoses etc.. Put a pipe over the end for a total length of about 3 feet and "jerked" the bolt loose .I would estimate it was at least 120 ft lbs...
Two questions, do these adapters always develop leaks over time? We have two 99 XJ's and both leak ( the screw on filer is not leaking)
Catalog shows two O rings to buy ?
