xcm
- Southern Oregon
so an aquaintance of mine bought an 88 xj, 4.0 4x4 w/ 242.... and he immediate ran into problems, trans, and a valve cover gasket that dumped oil..... So today we fix the valve cover gasket, and now we are getting finicky oil pressure readings. you start it up, it goes to like 20psi, then it slowly starts to drop.... eventually droping to zero... if you rev it up, it raises a little bit, but not back to full 20psi or so. im in a bad situation, because its getting driven to work tommorrow, how do i know? wait for the call that its dead on highway? btw, autozone lists a oil pressure SWITCH... i assume thats the one? hard to beleive its only $13...
