morgan320i
- oakley
so iv tried doing some research into this problem i have cant find anything, i am getting leaky oil that seems to flow from the head gasket, everyone says its not posible as its not pressurized, so far iv change dipstick o ring, oil filter adapter o rings, all the vacuum lines on the vc, also replaced the vc gasket with a felpro perm, everything is torqued dry up top i pressure washed the motor wih degreser, did a compression check all show same good psi, and my rad fluid is green as ever, also changed the dizzy gasket and the oil pressure unit, trying to change anything that leaks over here with no change
this is after 30 min of driving
