88mj40
- EUREKA, CA
I purchased PN 52019278AD Mopar OEM mount from CarID not long ago for my 1988. I found the Anchor mounts were too soft, (trans actually would bounce around so much that it popped out of gear), and the aftermarket poly mounts were too hard, (horrible vibrations).
The 52019278ad came up as fitting a 1997 TJ, but looked and fit the same and solved my problems. I did have to drill the through bolt out to a slightly larger size. Most of the aftermarket suppliers, Brown Dog, Sinky Fab, ETC show the same PN for the XJ and TJ, so I'm assuming they just ship them with the larger hole.
The OEM trans mount is still available, Mopar 52002334, Plate-Transmission Mount
https://www.moparpartsgiant.com/part...~52002334.html
https://www.moparpartsgiant.com/par...&year=1997&submodel=&extra1=&extra2=&filter=()
