I need help with a '94 Cherokee.This thing will just stop running,may or may not restart.No warning,just like key gets switched off,runs fine otherwise.Not a fuel issue.I can start throwing parts at it,and probably get it,but I'd rather not do that.Going to pull the coil and test,or have it tested.Also have to replace the oil pressure sending unit,it's leaking and the light is on.Wondered if there's a low oil pressure cut off built in somehow,haven't found anything on that.Several people have said it's probably the crank position sensor.Did the clutch a few months ago,r&r the crank pos. sensor,I think the problem was before I did the clutch though.Going to double check the harness,original equipment and has 150k+ on it.
2.5 I4, 2wd by the way.
Just used the self diagnostic and got these codes:
1991-95 Models
Code 11-Camshaft signal or Ignition signal-no reference signal detected during engine cranking.
Code 12-Memory to controller has been cleared within 50-l00 engine starts.
Code 55-End of message.
1991-95 Models
