94XJ2door5speed
- Norwich, CT
Will an O2 sensor be affected by heat. Now i dont mean the exhaust gas temp i mean cold weather or hot weather. I know sounds like a dumb guestion but i can't tell if its my ignition coil or O2 sensor that is causing the skip. The skip only occurs when the motor is up to temperature and is also affected sometimes by percipitation. It sounds like a cap but the cap is brand new and it isn't just a single cylinder skip it is a whole engine miss fire. The plugs are white which suggests its lean so i am thinking its the O2 sensor but not sure if that would cause the engine to run lean in the mid rpm range or not.
