Nv241or from 2012 JK rubicon
Unibuddy
Roanoke, va
This case has fewer than 200 miles on it and a clocking ring with three positions. This will fit in a Cherokee, however if you clock it flat the transmission tunnel will need to be modified. You can reuse your stock linkage for this, but I have linkage that can be included if desired. $1200, also interested in trades for the same case from a TJ Rubicon, a 231/300 doubler, upgraded Dana 30 parts, or an 8000-10000lb non integrated solenoid winch. I can be reached at 803-201-9323 and the case is located in Roanoke, VA
