czaplicki
- Huntsville, Al
I have a NP424 transfer case and it is leaking fluid out the back where the rear drive shaft connects. I was told it is the rear output shaft seal. But someone else said it is the bushing and oil seal. I will post photos as well.
Also do you have a part number for it?
I'm sure there is a how to out there to fix it. If someone doesn't mind posting a link for it!
Thanks in advance!
Thanks in advance!
