Northwest Karma 2018
GI-John
Mount Holly, NJ
I've been following other chapter's Karma threads and thought that it might work up here.
Please post up what you would like to GIVE to another member of the NWC.
If you want anything it's up to you to figure out the logistics. Priority to paid members over users.
John
Re: Northwest Karma 2015
Got a doughnut spare I don't need. Any one else want it before it gets recycled?
early model XJ fuel tank with pump
2 ZJ fuel tanks (no pump)
Ford dana 60 rear, semi float..
Located in SE PDX..
Located in SE PDX..
All still available..
Plus, 5.9 ZJ motor, Cracked head, and I'm keeping accessorys.. PM for details, Ran good when the head cracked.. great for a builder
I have some Dana 44 stuff I don't need so if anyone is interested let me know.
Full width Dana 44 (front) shafts. Rusty, but with new u joints I'm sure they'd be fine
Dana 44 knuckles, caliper brackets and spindles (not sure on year 70's?)
Also have an open carrier with spider gears
And a Dana 44 mini spool (and carrier) from a Xj 44 rear
I will take it all. I just messed up my foot though so I'm not sure how soon I can get over there.
It's all yours then!
Black Comanche bench seat cover. Trying to clear it out of the garage.
just did a sye so I have a np231 shaft and tail housing, and a stock driveshaft with one new u-joint up for grabs. just in case anybody wants it before I recycle. from an '87 4.0 auto d44.
also have a 1.25" receiver with ~2" drop hitch and 2" ball. The hitch is stuck in the receiver.
I have a dana 35 3.07 open carrier and a stock xj leaf pack with add a leaf if anybody would like to come get. I'm in se portland
I think so, we just moved so unless my wife tossed it, it should be in the garage somewhere.
I have a complete set of 8.25 drums to whoever needs them. They have about 10k on the current shoes, and worked well.
Also, have a stock steering box that leaks, but would be a good core.
I have a lot of used stock parts that came off my 87. Let me know if you want anything.
Stock:
leafs - lil saggy and need some new bushings and cleaning
Coils - also little saggy
Trackbar and bracket - needs a new joint on the bracket side
Lower control arms - probably needs new bushings
Rear swaybar
Shackles - needs bushings
Spare tire mount
Some vacuum lines - hard and soft
Full np231 tcase from a 96 that's in pieces
Fender flares - fronts are cut a bit from when I removed the air dam
Aluminum valve cover
Rear brake line
Not stock:
RE 3.5 swaybar end links - needs 2 sleeves
36.5 "custom" extended rear driveshaft - not balanced, maybe a trail spare if it'll fit for anyone.
