XJMallCruiser
- Orange grove tx
Ive posted this on another site with no luck and searched google to no end... It does it only when coasting not under power... When your coasting and throw it to nuetral it quits an if you remove the rear drive shaft it quits... Ive replaced the u joint at the differential the one at the transfer case feels fine... Ive changed the diff fluid an inspected the ring an pinion an spiders an theres no chips broken teeth or unusual wear... The pinion has no front to back side to side or top to bottom movement... I have a 6.5 rough country lift... 33's.. A dana 35 rear aw4 trans an np242 transfer an a transfer drop... Im fixing to order a hack an tap since it quits with out my drive shaft an i need one anyway...
